1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74528 03/10/2007 1:00 AM | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | Are there some 235 engines with out casting numbers? I'm looking at a parts engine and no amount of wire brushing has exposed the casting number in the expected location (just in front and below distributer in sidemount area) Best guess is that this is around 53-54 235 truck engine. Egine attached to floor shift four speed. No head. Engine id # appears to be 00I2251F54X. Trying to figure out if this engine has a flywheel with an 10 3/4 inch clutch.
Thanks, | | |
#74529 03/10/2007 2:03 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Well, Donf, our blocks must've come from the same place because I can't find any casting no.s either. I think the no. is supposed to be just above the starter location but mine says something like CON 54 A. I did decode my engine id# somewhat and so here's a little info for you: the F54X tells you it was made in Flint, MI, it is a '54 235 block, the X means a standard shift but that's about all I can come up with. Hope this helps a little. | | |
#74530 03/10/2007 4:07 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Donf,
What is the block casting number that is at the upper right of the starter.
Tim | | |
#74531 03/11/2007 9:37 AM | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | I too have no casting # near the starter location and my 235 engine is from a Canadian built '62 Biscayne. | | |
#74532 03/12/2007 1:13 AM | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | Tim,
Don't recall a casting number right of the starter. Believe there was just a "GM". Can't look, it is in a pile of junk engines behind a machine shop and closed for the weekend. Pretty well figure it must be a 54 and will not have the 42-53 flywheel that I am looking for with a 10 3/4 inch clutch. The search continues.
Thanks, | | |
