3 members (mick53, TexasJim50, 66flea), 105 guests, and 3 robots.
Topics128,265
Posts1,058,364
Members48,485
#74426 03/08/2007 1:39 AM
can someone point me in the right direction? tearing down my 235 to put in a new cam. first time at this ok? when i unbolted the rockers 1 slipped and now i have an assortment of pieces! Where can i find an exploded view of thr rocker assembly? will be buying a new cam, push rods and lifters from patticks in the near future. any and all help will be appreciated.thanks
ole b97
#74427 03/08/2007 2:53 AM
old b97,
What year 235?
Can you post the block casting code (at the upper right of the starter)?
Can you post the engine serial number (pressed into the ledge in the block to the rear of the distributor)?
Tim
#74428 03/08/2007 4:05 AM
Shop manual
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#74429 03/08/2007 5:24 AM
My Webshot Photos]
#74430 03/08/2007 2:47 PM
Some parts of the rocker-arm assemblies are different for different year 235s. Some of us could post links to a picture of the assembly, if you know the year.
Also, lifters/tappets are different for different year 235s (if you are buying new lifters).
#74431 03/08/2007 11:19 PM
Do you know if the rocker assembly is the same on all 848 heads?
My Webshot Photos]
#74432 03/09/2007 3:51 AM
Here's what I've learned -- decent replacement hydraulic lifters are non-existent. There is someone up in Canada who can refurbish your old hydraulic lifters if in restorable shape. I can get you the contact details if this is what you are dealing with.
All of the aforementioned being said... I know too little about this topic to be chiming in if truth be told ohwell . It's just something that I "learnt" during my '57 235 restoration saga.
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
#74433 03/09/2007 1:22 PM
sorry for taking so long to get back. tclederman and a few others wanted the block code. i hope these numbers are the right ones. first number on block i found was con4h146 second number was 0496098f56x
#74434 03/09/2007 8:00 PM
oleb97,
Looks like you have a 1956 235 truck engine.
If you have an original 1956 head, then you should use a 1954-1957 rocker arm assembly (later blocks, heads and rocker arm assemblies had a few minor differences).
If no one else posts a picture of the 1956 rocker arm assembly, I will post one this evening or tomorrow morning.
Tim
