2 members (Ponchogl, Jon G),
365
Mod | | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | I have two holes for a wiper motor on the drivers side. I'm not sure what one I should be using. I'm also not sure if the motor I have is original. See Page 2. http://rides.webshots.com/album/579922456jFVpcIWas a passenger side wiper an option? I welded the hole up because I didn't have a motor for that side. There was a total of 4 holes for wipers motors, two on passenger 2 on drivers. Thanks, Jason | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I think if the motor were original, it would be a Trico vaccuum operated unit. I believe the passenger side was an option.
Im betting the hole that is supposed to be used on your truck is the one on the right side of your pic. I think its about 14" from the divider strip in the windshield.
Did you ever get my email involving GMC COE part numbers?
Jeff | | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | It has trico stamped on it so must be the original. Thanks for the measurements. I got your email on the part numbers.
Thanks, Jason | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I had my driver side wiper rebuilt by Wiperman. It has two controls. One pulls in/out the other turns. I think the turning one is supposed to adjust the speed, but I see little or no effect from it. Pulling the in/out lever part way does give a slower speed. | | |
