2 members (NJC, greenie-reddy), 159 guests, and 4 robots.
Topics128,260
Posts1,058,287
Members48,485
#742860 04/27/2011 1:03 PM
I have a Task Force truck I'm getting ready to paint. I'm going to use a sealer/primer, base-coat and clear-coat. I expect that a galleon of primer would be plenty. I probably will lay down 2-3 coats of base and 2-3 coats of clear. Would a galleon of each (base & clear) be enough?
Donsz #742930 04/27/2011 5:48 PM
I'm guessing you're ok on primer if it's 2:1 on the mix with the option of adding reducer to put down thinner ,wetter final coats.
Color is harder to gauge.... If you're doing EVERYTHING inside and out including entire cab/bed top and bottom you may want to have an additional quart or so handy. (Especially if (like me!) you have to deal with a a "do over" on an area. ) Materials are getting expensive, so this is always dicey.
As for clear, my experience is by more than you think you need. You'll use it!
mike
Squire #742953 04/27/2011 7:43 PM
I needed a gallon plus an extra quart to do mine, which is a longbed.
Bill Burmeister
LONGBOX55 #743223 04/28/2011 6:06 PM
Thanks for the info, very helpful.
don
