3 members (MRMEROTH11, Charles in CA, mick53), 150 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#743210 04/28/2011 5:33 PM
Hi All,
I am looking at the Lokar emergency brake cable set (rear) which is listed for '42 thru '54 ADs. Has anyone used this kit in a '55 to '59? I looks like it will work the same in the lokar images but they won't "guarantee" it will work.
Any help would be greatly appreciated.
Dan
Not sure on this one Dan,I'm not that familiar with TFs,but I'm quite suprised Lokar do not do a model specific set-up for your truck.
Have you tried contacting their Tech Advice?
More pix on Flickr.
I talked to them a couple of times but they won't hazard a guess. Surely someone has done this.
Regards,
Dan
Try Ecklers Trucks .
I just ordered the rear brake cable for my 56. I was cleaning the whole assembly and broke the screw end off one cable trying to remove a badly rusted nut. A little spendy, but they look right to me. BTW - welcome to Stovebolt! Have no idea why they have your post in Hi-Po unless you're going to hot rod it and that didn't sound like your question.
Dale
the rear cables for the TF series may be available at a FLAPS near you, look for Raybestos # BC91949
I used the Lokar cable LOK-EC-81FU, connector LOK-EC8001U and pedal LOK-EFB-9001 (all Summit part numers). I had to do a little fabrication (https://picasaweb.google.com/ChrisAurit/PhotoHistory#5378302407026738418) to set the pedal, but the setup works perfectly.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
