| | | Forums66 Topics128,051 Posts1,055,766 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I have a 49 chevy 1-ton truck, I have rebuilt the Huck wheel cylinders, Had the shoes relined, And drums resurfaced, When my shop was cool, I adjusted the brakes, After I get the temp. of my shop to 75 degrees the brakes lock up. Is this a vent problem?
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Never had that situation but my first instinct is the brakes are adjusted to tight. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'll second the over-adjusted theory. Sounds to me that there's just enough heat expansion going on the cause the bind. Try backing them off a tad and see what happens. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I had problems with brakes like this before, drove me nuts. I finally had to bevel the ends of the brake shoes.(the lining)I noticed after that, that most of the replacement shoes already had a slight bevel on the ends, but not neccesarily. The best I could figure the shoes were slightly bigger than the drum and just stuck in drum, after they ran awhile and got worn to the same profile as the drum it was fine. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I had problems with brakes like this before, drove me nuts. I finally had to bevel the ends of the brake shoes.(the lining) This is something I used to do on all my VWs. It also stops the new shoes 'grabbing' the drum. I think it's just good practice to do. Especially important on something as light in the front as a VW Bug! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | |
