1 members (klhansen),
173
Mod | | | Forums66 Topics128,080 Posts1,056,317 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74268 03/04/2007 10:31 PM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | I got the truck running this morning and noticed something strange.
The tapping noise that I noticed a while back was really loud when I started the truck...she had been sitting for over a week. Then after she was all warmed up the tapping reduced a lot...and almost just became part of the background noise.
Is there any chance I have a bad lifter? The lifters are hydraulic on the 292...so I am wondering if one of them is leaking out while the engine sits...and then fills up after running.
What are the chances of that?
Dave 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
#74269 03/04/2007 11:24 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | sablesurfer, Old lifters are like old mechanics, creaky and stiff in the early AM, but agile and Gazelle like when warmed up. This is SOP for a old engine...as long as it quiets down after it is warmed up, it is fine. Stuart | | |
#74270 03/05/2007 5:24 AM | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | Lifters on the 292 are easy to change and not expensive. If its chronic I'd replace them. I would use some Marvel Mystery Oil and run it for a while then change the oil and use Castrol 10W-30 and use some Lucas Addative. Should stop it. My preference is to use System 48 Plus off the net. I use it and have no valve train noise of any other mechanical sound. Just smooth and quiet. Its guaranteed. H. | | |
#74271 03/05/2007 5:36 AM | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Automarc and Henry are right on. Thats typical of older hydraulic lifters. If they quiet down after a while,,just live with it,,if you can. Marty | | |
