7 members (tclederman, fonz8261, Hotrod Lincoln, Bill Hanlon, Charles in CA, 49choptop, 1955 1 Series), 91 guests, and 3 robots.
Topics128,087
Posts1,056,375
Members48,442
I got the truck running this morning and noticed something strange.
The tapping noise that I noticed a while back was really loud when I started the truck...she had been sitting for over a week. Then after she was all warmed up the tapping reduced a lot...and almost just became part of the background noise.
Is there any chance I have a bad lifter? The lifters are hydraulic on the 292...so I am wondering if one of them is leaking out while the engine sits...and then fills up after running.
What are the chances of that?
Dave
1965 Chevy C-30 1-Ton
"Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching."
sablesurfer,
Old lifters are like old mechanics, creaky and stiff in the early AM, but agile and Gazelle like when warmed up. This is SOP for a old engine...as long as it quiets down after it is warmed up, it is fine. smile
Stuart
Lifters on the 292 are easy to change and not expensive. If its chronic I'd replace them. I would use some Marvel Mystery Oil and run it for a while then change the oil and use Castrol 10W-30 and use some Lucas Addative. Should stop it. My preference is to use System 48 Plus off the net. I use it and have no valve train noise of any other mechanical sound. Just smooth and quiet. Its guaranteed. H.
Automarc and Henry are right on. Thats typical of older hydraulic lifters.
If they quiet down after a while,,just live with it,,if you can.
Marty
