2 members (Frank50, Joe H),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,175 Posts1,057,056 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Hi, Do the drums come off seperately? or Do I remove hub with drum?
I'm swapping a 68 front suspension onto a 61 truck. (entire crossmember assembly) Will I be able to use any of the 61 brake parts on the 68? Thanks. Pete | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What do you want to do? If you want to work on the brakes or inspect them, pull the hub. For machining, you should leave them on the hub. If you are replacing the drums then of course they need to come off the hub. | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | I'm disassembling to do a brake job and turn drums. Donor truck was sitting so I'm pretty sure it needs everything.
Thanks for quick response. Pete | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I would guess that you want to pull the hub. Always a good time to check and grease the bearings.
