0 members (),
192
0
Mod | | | Forums66 Topics128,089 Posts1,056,143 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74200 03/03/2007 7:47 PM | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Hello everyone -
I am a newbie at restoration/rebuilding so I am looking for some guidance.
I have recently removed all body parts down to the frame of my 55 second series. The guy I bought it from has a rubber sealant material all over the pumpkin, so apparently it leaks if this is removed.
I have never done any rear end work and would like to try to replace the gaskets myself. How do you know what gaskets to order? How do you know what rear is even there?
Eventually I am going to upgrade the motor to a strong V8. Does anyone have any suggestions on what I could use to replace the old with (possibly used)that would work better in the long run?
Any help would be greatly appreciated!!!
Ross | | |
#74201 03/03/2007 10:35 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ross - if it's the original rear end, they were most commonly 3.90 .... clean it up good, check the pinion seal, redo the cover with some RTV silicone on it, and unless it's got some holes in it, it won't leak .... for awhile the stock rear can handle V8's fine, a buddy of mine has been abuseing one with a 427 with no problems, just make sure the pinion bearing/seal are ok, which is the place it may be leaking Bill | | |
#74202 03/03/2007 11:54 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 1stproject,
Are you indicating that the cover leaks, or the carrier (pumpkin) leaks. If it is the 'pumpkin', the axles will have to be pulled, then the entire carrier can be unbolted and new gasket installed.
This isn't a 5 minute job and requires a medium degree of skill...maybe that's why it was 'gooped' instead of properly repaired.
There are lots of folks on this site who would love to walk you through this repair. Good luck.
Stuart | | |
#74203 03/04/2007 3:40 AM | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Thanks for the information. I will take a closer look at it tomorrow and see if I can find where exactly it is leaking.
It is good to hear this is a strong read end. I have been reading up on what rear end could substituted and I was pretty dazed and confused after I got done reading posts from other members.
I am having a blast working with my truck. My seven year son is also having a good time helping me out. People like you both are a lot of help.
Thanks and I will most likely be back with some more questions.
Ross | | |
#74204 03/04/2007 3:50 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Before you tear into it, get yourself a manual, or check out the Online Chevy Manuals Project http://chevy.tocmp.com/. Good info there on repairing anything on the truck. That diff is plenty strong, it also boasts a larger ring gear and axles than the later units. There is a place, Toms Rearends, that makes a conversion to 30 spline axles, using later 12 bolt side gears, if you do end up needing to upgrade. I have considered doing this myself, but am going to do some more research first. Gaskets are still being made for this diff, Fel-Pro #RDS4304.
Bill Burmeister | | |
#74205 03/04/2007 6:21 AM | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | 1st -
I found a 78 Trans AM 2.56 posi rear differential off Craigslist locally and just this morning took it over to Western Drivetrain in Aurora to get rebuilt. He's changing the ring and pinion gear to a 3.08, adding a spacer and replacing bearings and if needed, the axles. Bill does good work and came highly recommended. So if you need assistance, I would look him up.
Also, when I install the new rear end, I'll have to figure out what to do with my old one from my 56 TF. Might be something to consider, especially since we're neighbors... | | |
#74206 03/05/2007 3:07 AM | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Well I looked it over. It appears to be leaking from the seal where the pinion housing(unsure of term) connects to the axel housing (once again, unsure of term). Basically on the drive shaft side where the pinion gears are housed and they attach to the axel hosing. Would this be the same gasket as would be used on the back side, where the housing cover connects to the axel housing?(Fel-Pro #RDS4304 - thanks Bill!) If so, is this managible for a newbie with some basic skills and a desire to learn? In adition...........Paul..... give me an email if you would be interested in talking more about the original rear end you are getting rid of. ( [email protected]) Thanks again for all of your help! Ross | | |
#74207 03/05/2007 3:13 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are talking about a front loading pumpkin then the answer is that the gaskets are different. If it is a 3/4 or 1 Ton, the front gasket is paper thin and the back one is like a regular one. | | |
#74208 03/05/2007 3:39 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The # I posted is the one for the 3rd member, if I can find the package (I know I've got it here somewhere! :hammering: ) I'll post the # for the cover gasket.
#74209 03/05/2007 4:25 AM | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | Ross,
I sent you an email yesterday. Go to your Stovebolt profile and you should see the email. | | |
#74210 03/05/2007 4:36 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Paul, that rearend is also a good change for guys with the AD trucks. I have a 52 Panel with torque tube that I'm am going to take out and insert the 56 rearend. Gets rid of the torque tube and gets me from a 4:11 gear to a 3:90. So don't throw it in the junk pile!!! | | |
#74211 03/05/2007 4:46 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 1stproject, A blow by blow on removing the carrier reads like a short novel. I have linked the shop manual for your truck so you can page through the procedure yourself and get a idea of what is involved. Bookmark the site...it's full of good stuff, good luck. http://chevy.tocmp.com/1955truck2shop/index.htm Stuart | | |
#74212 03/05/2007 5:07 AM | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | Achipmunk -
Good advice. I'm not junking anything until I have the truck complete or I can't find someone who can use it. Even then, I may still keep it for my next project... Stovebolt resources are tough to come by in Colorado. | | |
#74213 03/06/2007 12:28 AM | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Thanks for the shop manual link Stuart. I was just getting ready to ask if anyone had that because I am tearing down my rear axle and was not sure how to do it. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
