2 members (Nick in Manitou, 1 invisible),
342
7
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Hey Yall I was wondering if anyone knows of a way to put stock hubcaps on 4x4 rally wheels. I have a few Ideas but was wondering if its been done before? Thanks,
Chris SC
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Some pictures and measurements would help. You'll need to cut a hole in the front hub caps for the locking hub. I just dropped mine off at a machine shop. Sure hope they turn out nice.
| | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Actually I want to use the rally wheels on My 2 wheel drive C10 and use the stock hub caps. If I could find an 8" steel wheel with the same or close to the same off set, and still use the stock hub caps would be good too. I really want the wider stand of the 8" wheels but I also want the stock apperance. Thanks
| | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | They made some 7" and 8" wide stock steel wheels with the nubs for your caps. Fairly rare though. And pricey. If you want your caps on your rally's why not weld some nubs on. Or find someone who can widen your stock rims. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | weld only on bare rims, unless you like tires blowing up in your face.
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | weld only on bare rims, unless you like tires blowing up in your face. Sounds like the voice of experience.  If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Hurry up and get this figured out because I have the 4x4 rallys and some stock hub caps too. I will need pics and how to's when you get this done. Pidder padder! | | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Welding nubs sound like a great idea. Lot easier that what I had in mind. Hey Vern, I'll weld on the nubs before I mount the tires  Thanks, | | |
