1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Hey Yall
I was wondering if anyone knows of a way to put stock hubcaps on 4x4 rally wheels.
I have a few Ideas but was wondering if its been done before?
Chris
SC
Proud Southern Stovebolter
Share the past for our future:)
1964 C10
http://s679.photobucket.com/albums/vv153/chrisgardner07/CGG_64C10/
Some pictures and measurements would help. You'll need to cut a hole in the front hub caps for the locking hub. I just dropped mine off at a machine shop. Sure hope they turn out nice.
Actually I want to use the rally wheels on My 2 wheel drive C10 and use the stock hub caps.
If I could find an 8" steel wheel with the same or close to the same off set, and still use the stock hub caps would be good too.
I really want the wider stand of the 8" wheels but I also want the stock apperance.
1964 C10
They made some 7" and 8" wide stock steel wheels with the nubs for your caps. Fairly rare though. And pricey.
If you want your caps on your rally's why not weld some nubs on.
Or find someone who can widen your stock rims.
weld only on bare rims, unless you like tires blowing up in your face.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Sounds like the voice of experience. wink
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Hurry up and get this figured out because I have the 4x4 rallys and some stock hub caps too.
I will need pics and how to's when you get this done.
Pidder padder!
Welding nubs sound like a great idea. Lot easier that what I had in mind.
Hey Vern, I'll weld on the nubs before I mount the tires smile
1964 C10
