3 members (MickeyP, Otto Skorzeny, Wally / Montana), 145 guests, and 1 robot.
Topics128,052
Posts1,055,728
#740325 04/18/2011 5:51 PM
What if one were to use a single piece of exterior grade oak plywood as a bed with strips bolted through. What are the pitfalls of this idea snd how should the wood be finished?
Hawkguy54 #740406 04/18/2011 10:35 PM
Thats what I did, cept I used cabinet grade since I have alot of that on hand. Sealed it with epoxy (also have lots on hand), and bolted SS strips down on it. Did not rout grooves...wanted the strips above the wood for protection.
Toughest thing would be sealing the edges and holes well enuf to prevent water getting in and swelling / warping plywood. Also with oak ply, you don't get the grain variation you see with individual planks. Veneers are pretty thin surface. Make your own planks. I bought 1 x 6 & 1 x 8 dressed Oak at a wood worker supply place for around $ 125.00. Grooved the edges with a table saw.
1940 Chevy KC 1/2-Ton
Britcon #740546 04/19/2011 5:54 AM
delamination of plywood is a certainty.....
GMC: Get More Cash...
1958 GMC
My Webshots photos
What are your reasons for wanting to go that direction? Durability? Beauty? Ease of installation? What is your goal?
If you are trying to do this with as little work as possible, just throw the plywood over the top of what is there. If you have to take it all apart to put the boards in, and you are just using the truck for a driver or a "not for show", just get some 1 by's and cut them to fit. I believe the instructions can be found here at the bolt or at Mar-K (look in the upper left of this page). I just used some good construction lumber and used a good UV resistant deck finish on mine. Replacing the boards as they were from the factory will eliminate a ton of squeaks and rattles too. http://www.mar-k.com/bedwooddimensions.pdf
Builder #742615 04/26/2011 3:05 PM
Mine is done that way and 4 years old(I keep it garaged)
still looks great. I did seal it top,botom and sides. Ieven inset the strips as normal on a table saw. Dado blade.
