0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | My new purchase is supposed to have many new brake parts and I have no reason to doubt that. However, the park brake cables were not re-connected to the crossbar. There is a 3 inch gap between the clevis on the hub cable and the mounting point on the crossbar. The triangular piece that slips on the crossbar is moveable, but I would think that changing that would be unnecessary. Surely the brakes would engage if it were possible to pull the cable 3 inches. What am I missing? Thanks.
All you can do is all you can do.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | What Model? What year? Can you take a couple photos of the cable at the drum area and of the triangular piece that slips on the crossbar? I think we can zero in on your problem with proper Info and pictures. Jerry
| | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | I gave one side a hard pull and got some slack out of it.I will tug at the other side tomorrow and tie it all together if it will reach. Hopefully it's all connected properly inside.BTW, it's a '50 ton dually with a grain bed and hoist.It needs good P. brakes so I can check that it's empty Thanks.
| | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | Got them connected today and they seem to work well. Lights are next and a passenger side mirror. Then, the hoist control cable.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 |  Way to go. | | |
