Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#741070 04/20/2011 10:58 PM
This may be a foolish question , but, in trying to get my 54 235 to tic the shop manual states to line up the U/C mark on the ring gear with the pointer. In the searches on this forum there is either an arrow or a silver ball that you line up with the pointer.My ring gear has both so which one do I use? This is a canadian built truck if it makes any difference. Thanks
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
Hydra1/2ton #741071 04/20/2011 11:07 PM
The ball is on the flywheel and the pointer is on the bell housing when you're timming you'll see the ball behind the pointer .Theres a hole just above starter in the bell housing and you'll see the pointer in that hole.
Pete
Pete52 #741085 04/20/2011 11:53 PM
U/C is the TDC mark. The ball, which will be a few degrees advanced from TDC is what you use to set ignition timing.
waldo53 #741090 04/21/2011 12:01 AM
Ah, so the arrow on the ring gear is the U/C mark,that is why there is both.It seems the 2 get interchanged in old forum posts. Thanks
Murray
Hydra1/2ton #741113 04/21/2011 1:32 AM
We have success , truck is running
