| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | This may be a foolish question , but, in trying to get my 54 235 to tic the shop manual states to line up the U/C mark on the ring gear with the pointer. In the searches on this forum there is either an arrow or a silver ball that you line up with the pointer.My ring gear has both so which one do I use? This is a canadian built truck if it makes any difference. Thanks | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | The ball is on the flywheel and the pointer is on the bell housing when you're timming you'll see the ball behind the pointer .Theres a hole just above starter in the bell housing and you'll see the pointer in that hole.
Pete
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | U/C is the TDC mark. The ball, which will be a few degrees advanced from TDC is what you use to set ignition timing. | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | Ah, so the arrow on the ring gear is the U/C mark,that is why there is both.It seems the 2 get interchanged in old forum posts. Thanks Murray | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | We have success , truck is running | | |
