| | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | I'm tearing into my art deco COE and am wondering if the COE cabs are really that different from the pickup cabs. The doors are different along with a rocker panel/sill plate metal piece that bolts in place. But other than that it looks like a PU cab. Anyone have any thoughts on this. I don't know the art deco PU cabs at all I just thought it was interesting that the rocker/sill sheetmetal bolted in. See pics. http://rides.webshots.com/album/579922456jFVpcI | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Like you mentioned, other than then the front lower rockers/doors and the floors, they are fairly identical. All the parts from a pickup to a large truck will pretty much swap out.
Jeff | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | On my 46 COE chevy the windshield - dash - seat - all glass - top cowl vent and wiper are all identical to a pickup | | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | I knew all that stuff matched. I also think the the entire cab minus the sill plate deal is the same. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | Right but I see from your pics a lot of different parts from a Chevy COE and a GMC COE. The floor hump over the valve cover is totaly different and mine dosen't have those dividers under the seat. Are your left and right floor inserts steel? Mine are plywood.
| | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | Yes my floor pans are steel and my valve cover does not come back into the seat frame. The GMC has 2 bomber looking seats the shifter comes up between them and I have a hand lever I push to the right of the driver seat that engages the starter. I wonder if chevy floor panel were wood from the factory. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | I'm 99.9% sure they were wood.I have the starter pedal right in front of the seat and the linkage gos in between the intake and exhaust manifolds.It's wild how they are two totally different designs. | | | | | Joined: Oct 2006 Posts: 117 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 117 | COE cabs have vent doors in the sides of the cowl whereas the pickup cabs do not. | | |
