Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (tclederman), 123 guests, and 2 robots.
Topics128,277
Posts1,058,453
Members48,490
#740468 04/19/2011 1:57 AM
I am having a hard time removing my brake drums from my 52 3600. Is there some kind of secret I do not know about? I have removed the two screws and it still will not come off.
I guess we are talking rear drums? So you can turn the drums, correct? Is there any movement between the drum and the hub? If not you need to smack them with a hammer just outside of where the studs are. Go around in a circle and eventually you will see puffs of rust coming out. At some point you will be able to pull them off a bit. When this happens, slam them back in and keep working them back and forth.
1951 1 Ton Completed
A brass hammer would be best, as it is less likely to damage the wheels studs if you miss than a steel hammer.
Bill Burmeister
Thanks guys, that is what I have been doing. I guess I just have not been persistent enough.
Did you back off the shoes?
Maybe this advice isn't needed but this is where you really need ear protection. I learned the hard way on this one.
V
V Offline
I hope you have the shoes backed off! If not, the drums are not coming off without damage.
Penetrating oil around the hub to drum rust will help. Keep banging.
#740643 04/19/2011 4:14 PM
Leave the lug nuts a little loose,1/4 turn. Drive back and forward SLOWLY and step hard on the brake, this should loosen the drum from the axle.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
There is 2 I never thought of. I hope I remember them next time Iam faced with that problem Make sure you heat only the drum.
