1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#740213 04/18/2011 6:29 AM
So I'm thinking out loud, but I'm curious...
Has anyone swapped out an inline 6 for a v8 in classic truck? Does this require extensive mods? Do you need to modify inner fender wells?
I have a 1952 3100. I'm contemplating my future plans on the truck....
Do something! Even if it's wrong!
You can use your front I-beam and suspension, but probably be better off going with a mustangII or front clip from a Nova or Camaro. No you really wouldn't have any issues with the inner fender walls. It isn't just a bolt-in type of deal. There is some exstensive work involved. Oh, and a little bit of cash too.
Riding in the Passing Lane
There has been many of them done. The biggest problem is interference with the steering gear.
1972 Chevy c10 Cheyenne Super
Originally Posted by olememphis51
mustangII
Avaoid the mustang 2 like it was the Plague. It's not strong enough to handle a truck, Camaro or Nova would be better, even the I beam can be done, though there are fit issues with the steering box as mentioned. I have heard of guys using a Toyota truck steering box to clear, plus get power steering in the bargain.
Bill Burmeister
I have just finished the swap. I used the tube type motor mount and transmission mount with a th-400. I kept the stock axle and Im using the nolimit power rack and pinion to solve the steering problem.Im also using a aftermarket steering colum.
I was thinking of doing the same thing to my 50 truck. The 400 engine's exhaust manifold is very tight to the stock steering. Where did you pick up your "nolimit" kit? And what kind of steering column did you use? thanks
I got the nolimits rackand pinion from nolimit.net just google it. a bought a tilt colum from cpp.
I converted my '52 from a 235 to a 350 V8 too. But I'm probably on a tighter budget than most other people too, or at least it feels like it.
I used the stock suspension and just a crossmember conversion from Speedway Motors. I also still use the stock steering gear. In order to gain the room for it, I turned a pair of shorty headers upside down and still had to space the steering gear out about an inch.
Everything works fine, but I do need to get rid of that stock steering gear.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
