0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | So I'm thinking out loud, but I'm curious...
Has anyone swapped out an inline 6 for a v8 in classic truck? Does this require extensive mods? Do you need to modify inner fender wells?
I have a 1952 3100. I'm contemplating my future plans on the truck....
Do something! Even if it's wrong!
| | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | You can use your front I-beam and suspension, but probably be better off going with a mustangII or front clip from a Nova or Camaro. No you really wouldn't have any issues with the inner fender walls. It isn't just a bolt-in type of deal. There is some exstensive work involved. Oh, and a little bit of cash too. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There has been many of them done. The biggest problem is interference with the steering gear. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Avaoid the mustang 2 like it was the Plague. It's not strong enough to handle a truck, Camaro or Nova would be better, even the I beam can be done, though there are fit issues with the steering box as mentioned. I have heard of guys using a Toyota truck steering box to clear, plus get power steering in the bargain.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | I have just finished the swap. I used the tube type motor mount and transmission mount with a th-400. I kept the stock axle and Im using the nolimit power rack and pinion to solve the steering problem.Im also using a aftermarket steering colum. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I have just finished the swap. I used the tube type motor mount and transmission mount with a th-400. I kept the stock axle and Im using the nolimit power rack and pinion to solve the steering problem.Im also using a aftermarket steering colum. I was thinking of doing the same thing to my 50 truck. The 400 engine's exhaust manifold is very tight to the stock steering. Where did you pick up your "nolimit" kit? And what kind of steering column did you use? thanks | | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | I got the nolimits rackand pinion from nolimit.net just google it. a bought a tilt colum from cpp.
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I converted my '52 from a 235 to a 350 V8 too. But I'm probably on a tighter budget than most other people too, or at least it feels like it.
I used the stock suspension and just a crossmember conversion from Speedway Motors. I also still use the stock steering gear. In order to gain the room for it, I turned a pair of shorty headers upside down and still had to space the steering gear out about an inch.
Everything works fine, but I do need to get rid of that stock steering gear.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
