| | | Forums66 Topics128,050 Posts1,055,760 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Will a 3/4 ton starter work on a big truck? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | How big a truck. If you are talking 2 ton or so, yes it is the same. | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | I bought a motor with transmission that was out of a grain truck. It had a starter with it. The starter has a cylianoid on it. The starter works just fine but wont turn the motor over. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year and size of "big truck" 47-55?
54/55 (at least) 2-ton GMC COEs came with a solenoid-starter.
Chevrolet double-duty (forward-control - step-van) trucks and trucks equipped with automatic transmissions had starters with solenoids (as did 49-54 cars).
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Are you sure you are matching 6volt to 6 volt. A 12 volt has a different tooth count and will not turn the engine. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | | | |
