0 members (),
80
Mod | | | Forums66 Topics128,062 Posts1,055,857 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74005 02/28/2007 12:09 AM | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | I finally found an overdrive trans to put in my stock 56 pick up. It came from a 55-56-57 car. My truck did not come with overdrive originally.I don't have all the hardware to make it like stock, but don't really care. I just want it to work. Can I wire the trans locking the overdrive in the "on" position all the time and put a switch in the 12V power to the solinoid for use to engage the OD? Will this work? Is there a better way? Thanks | | |
#74006 02/28/2007 12:36 AM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | oldschool56 I hooked mine up like this. I installed a relay on the firewall to handle the power to the transmission relay. I then installed a switch between the ground on the firewall relay and the govener. This switch allows you to turn power off to the relay. With the power switch on, the transmission relay will activate at about 28mph through the govener. You can also turn it off if needed. The dash switch also can be used as a kick down switch. When in over drive and you want to pass a car just trun off the switch and let off of the gas and you are in direct drive. I then went to NAPA and got a heavy duty locking type throttle cable. I hooked the cable to the transmission lever to be able to disenguage the overdrive when nessary. Attach the outher end of the cable under the dash. You are probably confused by now so I'll stop. Hope this helps. Tom | | |
#74007 02/28/2007 3:51 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I did mine virtually the same, though I got lucky and managed to find an original KD switch. I used a 40 amp headlamp relay (Standard-Bluestreak part # LR-32) and a Chelsea pto cable to operate it. So far, I've never had to go so far as to need to activate the KD, those 235s have so much torque that I haven't needed it to pass anyone.
Bill Burmeister | | |
#74008 02/28/2007 6:55 PM | | Anonymous Unregistered | | Anonymous Unregistered | I would keep the lockout cable, otherwise, when the overdrive is not engaged, it will freewheel and you will have no engine braking. I didn't use a relay with mine. Just a heavy duty switch on the dash to energize the solenoid. Drove it like that for 12 years with no problems. | | |
#74009 02/28/2007 8:38 PM | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | Many thanks to all who wrote. Looks like I am on the right track. | | |
#74010 03/01/2007 7:21 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Eric has it right. I put a passenger car o.d in my dad's 66 pickup and bypassed the governor with a hot wire from the switch on the dash to the solenoid. Worked like a charm, the guy that bought the truck died,his son still has it and the o.d. still works fine just as I wired it in 1966. | | |
