4 members (Samantha, KEVINSKI, mk72, 55shaker), 91 guests, and 2 robots.
Topics128,035
Posts1,055,552
#740085 04/17/2011 10:24 PM
Will a 3/4 ton starter work on a big truck?
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
Bart #740091 04/17/2011 10:44 PM
How big a truck. If you are talking 2 ton or so, yes it is the same.
crenwelge #740179 04/18/2011 3:33 AM
I bought a motor with transmission that was out of a grain truck. It had a starter with it. The starter has a cylianoid on it. The starter works just fine but wont turn the motor over.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Tom R #740447 04/19/2011 1:09 AM
What year and size of "big truck" 47-55?
54/55 (at least) 2-ton GMC COEs came with a solenoid-starter.
Chevrolet double-duty (forward-control - step-van) trucks and trucks equipped with automatic transmissions had starters with solenoids (as did 49-54 cars).
tclederman #740510 04/19/2011 4:00 AM
Are you sure you are matching 6volt to 6 volt. A 12 volt has a different tooth count and will not turn the engine.
crenwelge #740621 04/19/2011 2:56 PM
Good point!
