1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Hello all, I'm trying to title my 53 5 window, 3100. Problem is the title is from MI and I live in FL so the vin number has to be verified against the title. I have looked all over the truck for a vin number, the engine number and the number on the plate inside the drivers door do not match the title. Where else could the vin number be located.
Charlie
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Charley,
On a 53 you have the door tag and the engine number that is it. This topic is discussed a lot here do a search and you will see. You need to research the Florida DMV rules for what has to be done. The non-match on the title sounds like it could be a major problem, maybe one of the Florida Bolters will chime in. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Charlie (Charley),
Brad has nicely explained this situation. If you post the various codes that you have, people will be able to help you figure out a variety of things related to title, registration, engine serial number vehicle serial number (vehicle ID), etc.
- the engine serial number is pressed into the block just to the rear of where the distributor goes into the block
- the vehicle (cab) serial number is on a metal plate that is screwed or riveted to the cab between the driver's side door hinges
Either of the above codes might have been used on the title and/or registration.
| | | | | Joined: Oct 2010 Posts: 42 New Guy | | New Guy Joined: Oct 2010 Posts: 42 | Charlie, I had a similar issue with a title from OR that didn't match anything on the truck. Oregon DMV spent a lot of time helping me out and eventually told me that in 1950 the state assigned the number on the title and that had nothing to do with any ID/VIN numbers from the truck .... so you may be on a wild goose chase.
My state (CT) didn't car about a title, I just had to go through a VIN verification process where the technician compared the VIN plate on the door jamb to the bill or sale. Took all of 2 minutes, brought the form to DMV, plates issued. Newbie 1950 Chevy 3100 | | |
