7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | I took the 51 out for a drive today and went a little longer than I usually do. I started smelling somthing hot so I went home and parked it. Now I just tried to go out and move her into the shed and the peddle is rock hard (no give) and she won't move forward or back. Did I boil the fluid or can the pads stick to the drums? Just wondering what ya'll think.
| | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Well, they cooled down and let go. Guess I am going to need some adjustments to them. | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I had the same problem with my 46 last year (it drove me nuts!). It turned out to be a small vent hole in the master cylinder that relieves the fluid pressure in the lines. I cleared it with a tiny drill bit and used a magnet to make sure there were no metal chips in the MC. | | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Had the same problem with a Van back in England turned out too be water in the brake fluid.
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | I think I got it so hot that it expanded in the lines. I would think that if the brakes were in proper adjustment, then this probably wouldn't have happened, but I'm not sure. | | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Yeah I think if you have water in your brake fluid , And your brakes are dragging it heats the water up possibly too the point it makes steam this pressurises the brake system locking on your brakes as they cool down the steam will contract turning back into water and your brakes will ease off. This can then also allow pockets of air from the water boiling. Best bet too change out the nrake fluid and ease off the brake adjustment a bit . Ryan
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It happens when the brakes are overly adjusted and rub the drums constantly. Just need to back the shoes off enough for some expansion room, Scott | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | How much free travel does your pedal have? If not at least an inch or better an inch and a half the rod from your pedal into the master cylinder needs shortened. This causes more brake drag than any other factor.
Evan
| | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | I don't have much travel at all. I've smelled it a little hot before, but this time I touched the front drums and almost got burned. I think I will back them off a little. coilover, How can you tell how much needs to be taken off of the rod? I had an old timer do these breaks, maybe I'll go talk to him. Thanks guys for the replies. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If this is an original master cylinder, the pedal should return and stop moving because of a stop inside the master cylinder. You should have at least an inch of free play I would think. | | | | | Joined: May 2010 Posts: 20 New Guy | | New Guy Joined: May 2010 Posts: 20 | I took the 51 out for a drive today and went a little longer than I usually do. I started smelling somthing hot so I went home and parked it. Now I just tried to go out and move her into the shed and the peddle is rock hard (no give) and she won't move forward or back. Did I boil the fluid or can the pads stick to the drums? Just wondering what ya'll think. Several things may cause this issue. The main ones are incorrectly adjusted master cylinder push rod that leaves the compensation port in the master to not be fully open and bad flex lines that have collapsed on the inside and do not allow all of the fluid to return.
Ted My ride but looking for a Deco Bolt for the wife.
| | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | When I push on the peddle, It basically starts to grab right away. There might be 1/2" of play, if that. Sounds like maybe the rod does need to be backed off. Also, I did jack the truck up and the front wheels do drag quite abit when I try to spin them. Guess I'll be doing some work. Thanks again, Tim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim, Before moving into any other diagnosis (or speculation), check your toe-board clearance adjustment (for the master cylinder), and then adjust the brake shoes. Note that the 1951 instructions state to adjust to tighten until you get a drag; then back off 14 "notches". On my 1/2 ton 54, I tighten until the brakes shoes are really tight (to "seat" the shoes). Then, I start backing off until there is no drag. Then, I back off 7 notches (7 notches is what is called-for in the 1954 truck Shop Manual). | | |
