0 members (), 148 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
1 Offline
I have been told by several sources that the GMC rockers will fit in the Chevy sixes if the towers are shortened. I don't doubt my sources but I'm sure interested in the advice any of you astute gentlemen may have.
Normbc9
Why would you do that?
I don't think that would work. The Chev valves are on different angles, I believe.
1951 1 Ton Completed
1 Offline
Thanks truckernix.
I did get a call from Anderson, Ca at Rocker Arms and they have new in the box 1.6 arms for the 216. That will meet my needs perfectly. Since I have gone on the site I have obtained so much good information and tips from the members that it really amazing.
Normbc9
1.6? I thought the 216 rockers were a 1.4 ratio.
Some GMC rocker arms will fit Chevrolet 216/235s. It's roughly every 4th one or some such. The only reason I know is that my 248 broke several rocker arms and I only had Chevy parts to play with so I went ahead and tried them. They fit fine, just a little different in shape/size.
Some of the rocker arms work, at least half don't due to the different valve angles.
Jeff
My 1953 Chevrolet
1947.1 Gallery
1 Offline
Just to add to this I did find a new in the box full set of Chevy 216 High Lift Rocker arms and they were at a reasonable price.The use of any substitute is now off the table. Thanks for the comments and suggestions.
Normbc9
Never heard of high lift exhaust rockers.
