6 members (Tstan7, Gone, Napco Mark, ShopRag, Mike Roache, Hanks custodian), 79 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#699306 11/29/2010 5:55 PM
What is the weight of a 6500 Viking, and what is the total load it can carry?
http://chevy.oldcarmanualproject.com/chevyresto/59tld10.htm
Here I can read 14000 base gvw, and 21000 as max gvw. I can convert that to almost 10 tons, or 7 tons. But what is the empty weight of a truck like mine ?
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
lastchancetowing #699341 11/29/2010 8:17 PM
3B Offline
Hy lastchancetowing, according to my truck salesmans data book a 6503 curb weight is 5220 lbs., a 6503H curb weight is 5305 lbs., then you have to add whatever you think your tow deck weighs, 2 or 3 thousand pounds, hope that helps.
3B #699402 11/30/2010 12:17 AM
Bond Villain
Bond Villain
Ulf -- Is that truck on the boat yet?
Is your Lutefisk cooking??? Save some for me!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John Milliman #699549 11/30/2010 6:26 AM
It's 2 days from Brmerhafen Germany. Then a reload,and I expect it in Gothenburg Sweden 15 of december.
Then I only have 380km drive home in minus degrees and a LOT of snow brrrrr drive
Lutfisk is for christmas day here , so not yet. Damned, you got me hungry... smile
[email protected]
Also:
lastchancetowing #699670 11/30/2010 7:55 PM
I will sure be happy for you when you get your truck dance but even with the last name of Ensrud I will have to pass on the lutefisk eeeek
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
HevyHauler #699685 11/30/2010 9:17 PM
In the same 1959 manual (on page 20)
http://chevy.oldcarmanualproject.com/chevyresto/59tld20.htm
shipping and curb weight
tclederman #699707 11/30/2010 10:01 PM
In http://chevy.oldcarmanualproject.com/chevyresto/59tld21.htm
it says 15000 for bodu plus payload.
Gvw says 21000 here and 19000 there.
Still confused.
A 6500 model can carry what aproximately ?
Remove actual weight of truck from 21000 or 19000, or even 14000?
[email protected]
Also:
lastchancetowing #699860 12/01/2010 6:15 AM
Hi Ulf...
I have a somewhat similar truck, a '57 6400 series with a 12 ft. steel floor flatbed dump. My truck weighs 8500 lbs empty, the GVW is 19500 lbs giving me a payload capacity of 11,000 lbs. Your 6500 series should be GVW 19000 lbs or more. Your truck, being a bit longer than mine plus a heavier bed should weigh around 9000-9500 lbs. empty, giving you an approx payload of 5 tons, (10,000 lbs.)
To be completely safe make sure your tire ratings in total will meet or exceed the GVW you have. Get a true empty weight on a set of truck scales when you can. And the obvious....have your brakes checked out thoroughly, plus your steering.
Properly driven these old trucks can handle fairly heavy loads. I overloaded mine recently to 24,200 lbs and it handled no differently than at 20,000. I don't advise doing this, however.
James
1957 Chevrolet 6400 flatbed dump
Webshot pix
1942 Chevrolet 1 1/2 ton
1962 Chevrolet M80 tractor
oldiron57 #699871 12/01/2010 7:07 AM
Thanks. No I get it at last !!
And to be able to pass registory in sweden, weight is checked.
So that figure I will have exact. So, nice to know,aprox 5 tons will be what I am allowed to carry.
Of cource the brakes will have a checkup during next winter.
First year will be just testing everything out.
And remove stickers on the doors, and add some nice old style paint instead.
[email protected]
Also:
lastchancetowing #739208 04/14/2011 8:31 PM
An old thread, but still I would like to know...
GVW plate in cab says 16000 and custom papers say it had a weight of 2700 kilos. Does that make sense ?
Would mean to me that max weight, truck with load is 16000, about 7 tons.
So it means I can carry 7200-2700, which is 4.5 tons.
[email protected]
Also:
lastchancetowing #739316 04/15/2011 3:05 AM
Ulf,
If I converted correctly 2700 Kilos = 5950 USA Pounds.
16,000 - 5950 = 10,050 Pounds which means you can carry 5 ton USA.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
