| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | What is the weight of a 6500 Viking, and what is the total load it can carry? http://chevy.oldcarmanualproject.com/chevyresto/59tld10.htmHere I can read 14000 base gvw, and 21000 as max gvw. I can convert that to almost 10 tons, or 7 tons. But what is the empty weight of a truck like mine ? My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, according to my truck salesmans data book a 6503 curb weight is 5220 lbs., a 6503H curb weight is 5305 lbs., then you have to add whatever you think your tow deck weighs, 2 or 3 thousand pounds, hope that helps. | | | | | Joined: Nov 1995 Posts: 5,714 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,714 | Ulf -- Is that truck on the boat yet?
Is your Lutefisk cooking??? Save some for me!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | It's 2 days from Brmerhafen Germany. Then a reload,and I expect it in Gothenburg Sweden 15 of december. Then I only have 380km drive home in minus degrees and a LOT of snow Lutfisk is for christmas day here , so not yet. Damned, you got me hungry...  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I will sure be happy for you when you get your truck  but even with the last name of Ensrud I will have to pass on the lutefisk  | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | In http://chevy.oldcarmanualproject.com/chevyresto/59tld21.htmit says 15000 for bodu plus payload. Gvw says 21000 here and 19000 there. Still confused. A 6500 model can carry what aproximately ? Remove actual weight of truck from 21000 or 19000, or even 14000? My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | Hi Ulf...
I have a somewhat similar truck, a '57 6400 series with a 12 ft. steel floor flatbed dump. My truck weighs 8500 lbs empty, the GVW is 19500 lbs giving me a payload capacity of 11,000 lbs. Your 6500 series should be GVW 19000 lbs or more. Your truck, being a bit longer than mine plus a heavier bed should weigh around 9000-9500 lbs. empty, giving you an approx payload of 5 tons, (10,000 lbs.)
To be completely safe make sure your tire ratings in total will meet or exceed the GVW you have. Get a true empty weight on a set of truck scales when you can. And the obvious....have your brakes checked out thoroughly, plus your steering.
Properly driven these old trucks can handle fairly heavy loads. I overloaded mine recently to 24,200 lbs and it handled no differently than at 20,000. I don't advise doing this, however.
James | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks. No I get it at last !!
And to be able to pass registory in sweden, weight is checked. So that figure I will have exact. So, nice to know,aprox 5 tons will be what I am allowed to carry.
Of cource the brakes will have a checkup during next winter. First year will be just testing everything out.
And remove stickers on the doors, and add some nice old style paint instead. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | An old thread, but still I would like to know...
GVW plate in cab says 16000 and custom papers say it had a weight of 2700 kilos. Does that make sense ?
Would mean to me that max weight, truck with load is 16000, about 7 tons.
So it means I can carry 7200-2700, which is 4.5 tons.
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Ulf, If I converted correctly 2700 Kilos = 5950 USA Pounds. 16,000 - 5950 = 10,050 Pounds which means you can carry 5 ton USA. Mike B  | | |
