1 members (baldeagle),
22
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | 1950 3100 - Rear Window install.
Book says to install rubber on truck and work the glass in. I have tried and tried with no luck. Any tips?
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is the way it is done. I kept a couple of suction cups on the glass through the whole thing. I got it on the third or fourth try. | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Did you work in the left/right or top/bottom first? Any tips at all.. I keep feeling like any minute I am going to launch the glass across the shop and on to the floor.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | stovebolt member "Jockbolter" from across the pond posted some pics on his flicker site with comments that may help you. ...link... ...link... | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Does any of the venders sell only the chrome bead?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Make sure you have plenty of soap on it and it slids right in. The hardest part is holding the glass (like a greased pig). It works real easy as 2 person job. One to hold the glass and the other to pull the string. To put the retaining bead in, get a paint can opener, they work really well and of course plenty of soap.
Tape the rubber to the cab using good masking tape. It will tear as you pull the string. Then remove the torn peices of tape after the glass is in and before the bead goes in.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I didn't use a string on anything but the windshield. I too was afraid of the glass going flying. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | stovebolt member "Jockbolter" from across the pond posted some pics on his flicker site with comments that may help you. Thanks DADS50, Here's the actual link to the set. It'll save rummaging through all the cat pictures! Rear window install.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Thanks for the links and photos. The wife and I went out to the shop and gave it another try. We were at it for a good while but making progress. Alot of frustration, and stress, but we got it in. And to top it off.. As soon as the seal seated, and all was well.... The glass cracked top to bottom on the right side. Its a interior crack that you can't feel from either side, so I am just going to leave it for now. May just pay a glass shop next round.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | The glass cracked top to bottom on the right side. Its a interior crack that you can't feel from either side, so I am just going to leave it for now. May just pay a glass shop next round.  Another reason I had mine made in tempered glass,it's so much more forgiving.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | My shop manual for the ’65 suggests fitting the glass in the opening without the rubber to check for size to prevent cracking during/after installation.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | My shop manual for the ’65 suggests fitting the glass in the opening without the rubber to check for size to prevent cracking during/after installation. To add to that,the rear glass should be about 1/4" smaller than the aperature. This does not apply to front windshields. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
