5 members (Tronman, Otto Skorzeny, TUTS 59, Millenimech, 1 invisible), 116 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
1950 3100 - Rear Window install.
Book says to install rubber on truck and work the glass in. I have tried and tried with no luck. Any tips?
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/
Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time.
That is the way it is done. I kept a couple of suction cups on the glass through the whole thing. I got it on the third or fourth try.
1951 1 Ton Completed
Did you work in the left/right or top/bottom first? Any tips at all.. I keep feeling like any minute I am going to launch the glass across the shop and on to the floor.
stovebolt member "Jockbolter" from across the pond posted some pics on his flicker site with comments that may help you.
...link...
...link...
Does any of the venders sell only the chrome bead?
TIA
Dennis
Make sure you have plenty of soap on it and it slids right in. The hardest part is holding the glass (like a greased pig). It works real easy as 2 person job. One to hold the glass and the other to pull the string. To put the retaining bead in, get a paint can opener, they work really well and of course plenty of soap.
Tape the rubber to the cab using good masking tape. It will tear as you pull the string. Then remove the torn peices of tape after the glass is in and before the bead goes in.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I didn't use a string on anything but the windshield. I too was afraid of the glass going flying.
Thanks DADS50, Here's the actual link to the set.
It'll save rummaging through all the cat pictures! wink
Rear window install.
More pix on Flickr.
Thanks for the links and photos. The wife and I went out to the shop and gave it another try. We were at it for a good while but making progress. Alot of frustration, and stress, but we got it in. And to top it off.. As soon as the seal seated, and all was well.... The glass cracked top to bottom on the right side. Its a interior crack that you can't feel from either side, so I am just going to leave it for now. May just pay a glass shop next round. frown
Another reason I had mine made in tempered glass,it's so much more forgiving. ohwell
More pix on Flickr.
My shop manual for the ’65 suggests fitting the glass in the opening without the rubber to check for size to prevent cracking during/after installation.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
To add to that,the rear glass should be about 1/4" smaller than the aperature.
This does not apply to front windshields.
More pix on Flickr.
