3 members (66flea, Chris's 46 / 515, TUTS 59), 120 guests, and 2 robots.
Topics128,091
Posts1,056,445
Members48,443
#738348 04/11/2011 11:02 PM
Hi all,
The serrations under the heads of the door bolts for my '56 3600 are shot,no matter how tight,the doors keep moving.I have tried star washers to no avail,I have looked online but nobody has these bolts in fine thread.
Any help?
Dune #738365 04/11/2011 11:50 PM
only time I've seen them from the vendors is in complete hardware kits, might be able to find them at a hardware store or maybe someplace like McMaster-Carr
Do you have an ACE Hardware? In my areas they carry a big selection of all sorts and grades of bolts. Take one of yours with you.
Tried MC Master and ace and Google and...everybody has coarse thread but not fine, might get coarse and try to re thread.
Dune #738594 04/12/2011 6:02 PM
if you have a fastnal in your town they can get them
...link....
If your hinge bolt is the same as the 47 to 54 then classic parts has them
...classic link...
True value usually has a good bolt selection.
You may want to consider keeping the fine threads
Good luck
what I need is a flanged bolt with serrations under the head like this
//http://www.amazon.com/M8-1-25-Flange-Serrated-Bolts-Black/dp/B004625SN2, replacing the stock ones
Dune #738616 04/12/2011 7:52 PM
Well pop, that Fastenal is certainly the definitive answer, just exactly what the doctor ordered. I really like that when I don't have to spend three hours chasing down a suggestion.
Thanks for the link,
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
