| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | Hi all, The serrations under the heads of the door bolts for my '56 3600 are shot,no matter how tight,the doors keep moving.I have tried star washers to no avail,I have looked online but nobody has these bolts in fine thread. Any help? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | only time I've seen them from the vendors is in complete hardware kits, might be able to find them at a hardware store or maybe someplace like McMaster-Carr
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Do you have an ACE Hardware? In my areas they carry a big selection of all sorts and grades of bolts. Take one of yours with you. | | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | Tried MC Master and ace and Google and...everybody has coarse thread but not fine, might get coarse and try to re thread. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | if you have a fastnal in your town they can get them ...link.... If your hinge bolt is the same as the 47 to 54 then classic parts has them ...classic link... True value usually has a good bolt selection. You may want to consider keeping the fine threads Good luck
| | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | what I need is a flanged bolt with serrations under the head like this //http://www.amazon.com/M8-1-25-Flange-Serrated-Bolts-Black/dp/B004625SN2, replacing the stock ones | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well pop, that Fastenal is certainly the definitive answer, just exactly what the doctor ordered. I really like that when I don't have to spend three hours chasing down a suggestion. Thanks for the link, Denny Graham Sandwich, IL
Denny G Sandwich, IL
