4 members (klhansen, TooMany2count, Otto Skorzeny, Gdads51), 135 guests, and 2 robots.
Topics128,047
Posts1,055,533
Members48,424
#738429 04/12/2011 2:15 AM
so, I have an all original 52 , I think it is a " heavy half ton" as it has helper springs and 4 speed. It doesn't like much above 40 mph, and I hate to keep that old splash-lube 216 winding that high. My buddy has a 52 with the 3-on-the-tree tranny and no rear helper springs. It runs out nice at 55MPH , much more highway friendly.
My question is if the difference is simply in the tranny or did they use different rear end gearing in those years??
Help
52bolter #738439 04/12/2011 2:44 AM
It sounds like you haven't found 4th gear yet. The gear ratios should be the same, and 4th gear is the same as 3rd gear in the 3 speed. It is 1:1 on both transmissions.
How many lugs do your rear wheels have? Perhaps a previous owner swapped a 3/4 or 1 ton rear in for more grunt.
As stated the tranny's were all 1:1 and the rears were all 4:11 from the factory on 1/2 tons. There is an aftermarket ring and pinion set to change the ratio to 3:55 which may have been installed in buddy's truck and of course would not be visible.
You Tube
Curt B. #738600 04/12/2011 6:51 PM
Thanks for the insight, I do believe my buddy's drivetrain may not be all original. Do you know a vendor for the ring and pinion?
52bolter #738609 04/12/2011 7:11 PM
They are available from a few sources but I believe they all come from here which is where I bought mine:
http://www.patricksantiquecars.com/
You Tube
