5 members (WICruiser, Hotrod Lincoln, moparguy, Barney1951, Peggy M), 54 guests, and 2 robots.
Topics128,076
Posts1,055,920
Members48,429
#737864 04/10/2011 2:56 PM
I have installed a CPP tranny crossmember in my 58 apache. it is the kind that has the two end caps that bolt to the frame. My question is. After everything is set, do you run a bolt through the end cap and pipe? Or do you weld around. thanks for your input.
H Online: Content
Either way will work. If you're sure the position is right, weld it. If you think the angle of the trans output shaft might have to change, drill and bolt until you're sure the setup is good. How about removal later in case you need a transmission change- - - - -can you get it back out if the pieces are welded together?
I think welding cross members on a frame is a no no. For a fancy race car, or a show car its fine. But there is a reason that GM riveted those frames. And there is a reason KW and Peterbuilt bolt them together. Welding something the welded stucture needs to be properly reinforced to minumize stress that will crack and fatique the welded area, constant flexing will do that. In other words if your going to weld it, then it needs to be designed differently than the factory did it. I think bolting with grade 8 or higher is the best option.
Thanks for the info guys. I think I will run a bolt through the pipe. I might have to have the motor and transmission out a few mor times before my build is complete. Thanks again for the advise.
