0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 10 New Guy | | New Guy Joined: Jun 2010 Posts: 10 | I have installed a CPP tranny crossmember in my 58 apache. it is the kind that has the two end caps that bolt to the frame. My question is. After everything is set, do you run a bolt through the end cap and pipe? Or do you weld around. thanks for your input.
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Either way will work. If you're sure the position is right, weld it. If you think the angle of the trans output shaft might have to change, drill and bolt until you're sure the setup is good. How about removal later in case you need a transmission change- - - - -can you get it back out if the pieces are welded together? Jerry
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I think welding cross members on a frame is a no no. For a fancy race car, or a show car its fine. But there is a reason that GM riveted those frames. And there is a reason KW and Peterbuilt bolt them together. Welding something the welded stucture needs to be properly reinforced to minumize stress that will crack and fatique the welded area, constant flexing will do that. In other words if your going to weld it, then it needs to be designed differently than the factory did it. I think bolting with grade 8 or higher is the best option.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jun 2010 Posts: 10 New Guy | | New Guy Joined: Jun 2010 Posts: 10 | Thanks for the info guys. I think I will run a bolt through the pipe. I might have to have the motor and transmission out a few mor times before my build is complete. Thanks again for the advise. | | |
