| | | Forums66 Topics128,164 Posts1,056,968 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 4 New Guy | | New Guy Joined: Apr 2011 Posts: 4 | Hey guys pretty new here and I did look just probably not good enough.
I have access to a set of 1 ton springs and mounts but the spring eye rubber is bad. are these the same 1/2-3/4 ton eye rubber. More importantly are these available and where?
Thanks for any help...
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | There is no rubber other than the little grease seal washers. They use threaded type shackle pins and bushings.
Should be the same from 3/4 ton up to 2 ton.
Grigg | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...... I "think" the only way to get the rubber seals is in the shackle kits but I could be wrong. I haven't checked "all the vendors". I'd check around at some of the Spring shops as they may have some individual parts..... or get some dense type foam rubber and make your own. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you are referring to the top diagram: #3 is a front spring shackle kit (with rubber/cork "washers" (seals) and two bushings (for the spring eye at the front of the front spring and the frame mount)). #8 is the spring eye bushing for the rear of the front spring (no rubber seals). Part #7.435, Shackle Kit (front spring) - different parts for the 1/2&3/4 ton and for the 1 ton? Part #7.428, Front spring eye bolts are also different? But, I cannot find the 1-ton spring eye bushing (Part #7.104?) for the rear of the front spring? | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | If you are talking about the cork seals,Denny Graham made his own.Look on page 46 of his posts.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Apr 2011 Posts: 4 New Guy | | New Guy Joined: Apr 2011 Posts: 4 | Ok let me ask like this, Are pin/ bushing and shackle kits available for one ton leaf springs..
Sorry for all the confusion. I hope this clears it up..
doesnt look like they are so I should just look for 1/2 springs?
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | I got all the spring parts for my 51 1t at eatonspring.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Me too Everything is available. | | | | | Joined: Apr 2011 Posts: 4 New Guy | | New Guy Joined: Apr 2011 Posts: 4 | | | | | | Joined: Dec 2010 Posts: 15 New Guy | | New Guy Joined: Dec 2010 Posts: 15 | I used garden hose end washers on mine, cheap, available at any hardware store. | | |
