6 members (dwreills, Johnny Rib, Wickedbass, TooMany2count, 5 Window 9434, Joe H), 140 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#737868 04/10/2011 3:02 PM
1949 216 engine with a side mounted oil restricted flow oil filter. It seems that
these units filtered very little oil and thus would have a very limited affect in keeping the oil clean. Can this limited flow oil filter be converted to a full flow, and how could it be done? Further, should I even consider changing it or leave well enough alone? Thanks for the help.
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
A49ER #737876 04/10/2011 3:36 PM
Dave,
The by-pass oil filters work fine. They may only filter a small % of the flow, but all of the oil eventually goes through the filter and gets cleaned.
Someone else will have to comment on changing a 216 to allow a full flow oil filter.
I wouldn't change it either. I don't even have a filter on my truck. It gets driven 300-500 miles a year - maybe. So I just change the oil and I'm happy.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
my 40 was like that. when i had a 270 for the 40 and the ashton rebuilt that is when i did the full flow conversion with a remote filter housing while the engine was dismantled. when i had the 59-235 rebuilt for the 51-6100 i decided for how much running time it would have i decided to just go with the bypass filter. i just got a dmv annual inspection last thursday on the 6100. total mileage for the year was just over 1000 miles.
A49ER #737899 04/10/2011 4:54 PM
If anything, a bypass filter does a better job of cleaning up the oil- - - - -it just takes a little longer. Converting a 216 to full flow would be a big job, involving some very creative machining. Untold numbers of these engines ran millions of miles with the oil system it was designed to use- - - -why second-guess something that works because of the ridiculous rumor that the filtering is ineffective?
A49ER #738012 04/11/2011 12:39 AM
Guys:
You sold me, I'll leave it alone, I greatly appreciate the insight. Good to hear from you Jerry, and all you folks here at the Stovebolt. Be well.
Dave
A49ER #738155 04/11/2011 10:56 AM
1 Offline
I have a 216 with the old style filter that I still have as a Babbitt Pounder. It now has over 100,000 miles on it and going strong. If there were oiling issues I would have detected it by now. I use a high grade 10-30 motor oil with no other additives. I'm going to pull the head to take a look at the upper end soon. I did replace all the valves and seats when I built it up. I'm using a 248 GMC rocker assembly that I had the towers machined down to the length of the stock Chevy towers. That is still functioning well. I have an HEI unit on it and also a dual intake with heat and Carter/Webers from Stovebolt and cast iron headers.
Normbc9
