8 members (Gdads51, LAROKE, Phak1, JW51, Nick in Manitou, FAST55, Bill Hanlon, dt235sd),
86
Mod | | | Forums66 Topics128,138 Posts1,056,751 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Seems to be pretty well established method. Interested to hear some insight from those who've done it. My tank is full of rusty crud. Will follow the shaking with Por 15 clean, prep, and seal unless there's some better ideas out there.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If it is full of rusty crud you may want to consider replacing the tank.
rockauto.com sells a replacement tank for your truck for 167.00. Made by spectra. a Canadian company. Part number GM55A
Good Luck
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I've heard of using a length of chain too. If you use this process make sure you examine the tank for pin holes by dropping a small light into the tank and examining the tank in a darkened area. It may be that buying a replacement tank as suggested will be a better idea.
Drew
| | | | | Joined: Feb 2004 Posts: 29,841 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,841 | The problem is getting whatever is put in there back out. If there's a big access hole somewhere like the one for the sending unit, no problem. How about what gets trapped behind baffles where there's no easy access? I like to use small things like BB's, or 1/4" nuts, etc. that can be retrieved with a magnet. Mix up a strong solution of water-soluble parts cleaner soap. Fill the tank halfway with water, and strap it down in the bed of a pickup. Drive around for about a week. The sloshing action of the half-full tank and the normal agitation of bumps and corners will do the agitation for you. Jerry
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | everytime i took the 6100 out for a ride, i had to pull it home with my pickup and a farmer brought me home once with his tractor. realizing that it was dirt in the tank that was causing me the issues and not in a position at the time to buy a new tank i got this idea of taking a bunch of cleaned #2 stone and putting it in the tank with some heavy duty cleaner degreaser. i danced with the tank for an afternoon until i couldnt dance any longer. after i got all the stone out i flushed the tank numerous time with the hottest water i could find. after letting it dry with the hot sun beating on it i reinstalled it. i added a see thru filter between the tank and the fuel pump. i have'nt had to get a ride home since. as time goes on i have to change the filter out less and less. the hose i used is still full of varnish and on hot summer days i get all sticky from using it and it reminds me everytime how it got that way. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Buy a new Spectra Premium tank for it and be done with it. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | $167 is pretty good, was figuring about 50 more than that. If not for the cost of a new sender, strap pads, fuel line and other assorted junk I'd probably go that route. Seems to be a good salvagable tank. Don't think there's any baffles. tankHauling around in the back of the truck is a darned good idea, will take awhile for the Por to arrive anyway. Got some gravel in there right now and the manual shaking is wearing my butt out!
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | Block up one wheel of your tractor or other appropriate vehicle. Strap tank securly to wheel and add whatever (gravel, old rusty nuts, bolts, etc.). Start and let tractor idle in first gear for the afternoon. Results, clean tank and nuts and bolts look pretty good too. Just remember, if tractor falls off block, there is no stopping it. | | | | | Joined: Mar 2011 Posts: 58 New Guy | | New Guy Joined: Mar 2011 Posts: 58 | That's a fricking hysterical mental picture.... bet it works...LOL | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Except for the inside of the baffled area like Jerry pointed out. If a new tank is available that is probably the way to go. In my case that wasn't an option so I acid cleaned then lined the tank on my '38.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | If it is full of rusty crud you may want to consider replacing the tank. rockauto.com sells a replacement tank for your truck for 167.00. Made by spectra. a Canadian company. Part number GM55A Good Luck That seems like a really good price when you consider a POR-15 tank sealing kit here is £60(roughly $90) and the Spectra tank works out at £102. The £40 difference is worth the peace of mind knowing it's brand new. My own tank sounds in a similar condition to to Scotts As usual the killer for me would be shipping and import taxes. Sometimes it sucks being on the wrong side of the 'pond! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Check out my photo bucket pics under tank cleaning 1- pc. of thin wall conduit bent to match the tank and a BIG Son to turn and you're set.
Pete
PS I do think in the end you're better off getting a new tank by the time you buy everything to fix the old one and all the work . | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Jock, that's a good reason to come over for a visit and take an extra piece of "carry on" luggage back with you.
| | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | The last old tank I descaled. I fixed it on the end of my cement mixer and put a hand full of nuts in it and turned the mixer on. It roll it like an old rock polisher. Just an idea. lug | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Block up one wheel of your tractor or other appropriate vehicle. Strap tank securly to wheel and add whatever (gravel, old rusty nuts, bolts, etc.). Start and let tractor idle in first gear for the afternoon. Results, clean tank and nuts and bolts look pretty good too. Just remember, if tractor falls off block, there is no stopping it. I'd go ahead and block up both wheels if I were you. LOL! | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I used 1/4 in nuts and strapped it to a cement mixer. Then I replaced it because it had too many pin holes to count....never regretted the new tank.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Block up one wheel of your tractor or other appropriate vehicle. Strap tank securly to wheel and add whatever (gravel, old rusty nuts, bolts, etc.). Start and let tractor idle in first gear for the afternoon. Results, clean tank and nuts and bolts look pretty good too. Just remember, if tractor falls off block, there is no stopping it. That is a similar technique most companies use to clean chemical tanks. It works like a rock polisher. Fill it with a quarter tank of pea gravel and get it to spin some way (the tractor will work) and if you leave it spinning long enough it should clean around baffles as well.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jock, that's a good reason to come over for a visit and take an extra piece of "carry on" luggage back with you.  I wonder if could disguise it as a suitcase!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I used 1/4 in nuts and strapped it to a cement mixer. Then I replaced it because it had too many pin holes to count....never regretted the new tank. That is a good idea.. I have a 3 point mixer I could use if I ever want to give it a try. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | rockauto.com sells a replacement tank for your truck for 167.00. Made by spectra. a Canadian company. Part number GM55A I just ordered this tank from rockauto.com last week. I've heard very good things about the Spectra tanks here and elsewhere. The price was cheaper than anywhere else as well. It said they had 3 left before I ordered mine. I'm looking forward to receiving it. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Jock.
Just don't try to carry it back full - because gas is cheaper in the US. LOL
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I hope they told you the shipping charge....I paid $325 for a tank from Carter (which I still think was outrageous) but to add insult to injury, they charged $95 to ship it to me!!!!!!OUCH!!!!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The shipping charges for rockauto.com is very reasonable. For my area is $26.00 for ups ground. I found out about Spectra tanks by reading several post on this forum a while back. The vendors sell overseas made tanks for the AD trucks. From what I’ve read the filler necks don’t line up, and the thread on the bottom of the tank are metric and not pipe thread as original. The Spectra tanks are exactly as original. This info is for the AD behind seat tanks. I was going to clean and seal my old tank, but decided to buy new. ...pic... ...pic... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'll give a "thumbs-up" for Rockauto.com. The prices are good, the service is equal to the best and the shipping is reasonable. They carry parts for every car that ever was. They carry quite a lot of stuff for our trucks. Check them out.
~Jim
| | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Went ahead and coughed it up for a Spectra from rockauto. It's probably the best option although I'll keep the old tank, mainly because I hate turning loose of the old original parts for a variety of reasons. Next decision...to paint or not to paint?
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I received my Spectra tank today. It looks pretty good. Photos here | | |
