1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Is there any lower ratio ring and pinion sets for the 3600 pickups. Top seed on these dudes is 60 if you really push it.
Any thoughts?
Walt Williams La Verkin, UT | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Try a dana 60 from a Ford or Dodge van. It's a couple inches wider, but should fit just fine | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | 54Belair,I posted a complete drum to drum,that is all complete,with 456gear ratio,that I replaced with an S10 4wd truck,with 373posi-trac,and hooked it to an overdrive transmission.I was asking 200.00,or best offer.I am located in Piqua,Ohio. Which is about 30 miles north of Dayton,Ohio. You can always replace the pig if you wanted. The rearend I have for sale,is out of 1951 Chevy 3/4ton,3600.Thanks
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Z71 - it is OK to reference an ad you have posted in the Parts for Sale Forum but not OK to place an ad here which is what this looks like. Since your new I will not remove it but please be aware of the Administrators rules. Thanks. | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | My misunderstandings,I was just referencing the post.Sorry. | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | About what years of vehicles would the Dana-60 be found in? I would like to see if my local salvage yard might have one.
I do have a strong preference to want to keep my Chevy truck Chevy, but I will go look at one.
Thanks Walt Williams La Verkin, UT
| | | | | Joined: Dec 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 24 | My understanding is that the complete gear set from a '67- '72 Chevy 3/4-1 ton, with auto trans., is a direct bolt in swap,with, I believe 4:10 gears.
'52 Chevy 3600 '03 Chevy 2500HD '64 Pontiac Grand Prix '93 Jeep Wrangler
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The 4.10 will fit. The trick is finding one. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | For a Ford van Dana 60, I would try an early/mid 90's. For Dodge, just about any year should work. If you want to stay all GM, a 14 bolt may work also. | | | | | Joined: Dec 2010 Posts: 3 New Guy | | New Guy Joined: Dec 2010 Posts: 3 | that is correct I just put one in my 49 3600 out of a 69 3/4 ton gmc 4.10 bolted right up | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | opey so you are saying that you just swapped out the gears in the differential or you swapped out the whole axle? i have a 53 3600 and would like to get some more speed out of it
rolf
1963 c10 | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | If you find the elusive 4.10 rear, you change the whole center section. Unbolt the drive shaft, unbolt and pull the axle shafts, then unbolt the front of the differential housing. Don't drop it, it's heavy! Reverse the procedure to install. This keeps your original axle housing (and width) while upgrading your gears
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | ok then i'm looking for a '67- '72 Chevy 3/4-1 ton, with auto trans
are/is there a way to id the differential of that gear set? casting# or some sort of id number?
i'll be back on this thread if i find one
rolf
1963 c10 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There will be a code stamped on the front face of the carrier. I've posted the codes before, but for sake of saving a ton of searching for them, here they are again. 1967; HW, JU. These are listed as 4.11, may be Spicer rather than Eaton 1968; NA, NB, WI, RN (RN is listed as a 1 ton diff) 1969; NA, NB, OT, OW, OY, TF. There are also 1 ton listings; IE, LJ, LZ, MR, NZ, RN. 1970; TAA, THU, THW, TJU, TLN, TMZ, TNA, TNB, TOT, TTF, TWI. 1 ton; TIE, TIH, TLJ, TLX, TLZ, TMR, TNZ,TRN. 4x4 K20; TPW, TPX 1971; TAH, TAJ, TJA,TJB, TJP, TJS, 2G. 1 ton; TAK, TAL, TAP, TJK, TPZ. 4x4; TJH, TJJ,TKB, TKC, TKK, TKL, TKS, TKT. 1972; RAH, RAJ, RJA, RJB, RKK, RKL, RKS, RKT, RJP, RJS, RKB, RKC. 1 ton; RAK, RAL, RAK, RAP, RJK. 4x4; RJH, RJJ. I do have listings for a 3.54 ('71 and '72) and a 4.11 ('67-'72). but from what I understand, those are Spicer differentials rather than Eaton, though I have seen a '72 with a 3.54 code on an Eaton differential. BTW, most, if not all, GMC trucks from the '60s used a Spicer differential in the rear, either a Spicer 60 or 70 (I've senn them both ways).
Bill Burmeister | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | longbox will any of those listed above fit in the HO50? or just the eatons?
thanks rolf
1963 c10 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Bill, don't know who we need to contact but we really need to list that in the permenent tips section. I've had a bunch of guys PM me asking me to check the numbers that they have on a gear they are looking at. I find myself just repeating the same thing over and over. That info orta be out there for everyone to access.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I agree with you, Denny. I got the information from the Chevy Truck ID Numbers book from Cars & Parts. Rolf, the numbers listed are for the HO52 and HO72, essentially the same axle with the main difference being the brakes. They were manufactured by Eaton for Chevrolet. As noted, GMC used Spicer axles during that period, as did some Chevrolets with the leaf spring option, usually Camper Specials.
Bill Burmeister | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i've already saved that info to my computer thanks longbox i may already have a line on one
rolf
1963 c10 | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Highflyer
How about the axle shafts? Do they insert into the "new" gearing?
Walt | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | High flyer, Axel shafts slide right in Jerry
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | longbox i found a rearend stamped THW W14 (Then a number i couldn't make out) 2 on the front of the axle tube i also found one the junk yard marked as a 4.10 but the RYZ code isn't on the list
what tools do i need to get the gears out? and is ther a procedure published on how to go about removing the gears somewhere? i've never done it before thanks rolf
1963 c10 | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | From oldgmctrucks site, http://www.oldgmctrucks.com/page0276.htmlPictorial with descriptions of what you are wanting I believe.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks randy it seems simple enough is there a name for the company referenced in the article? if it's available i'd go with the 3.90 he mentioned
thanks again rolf
1963 c10 | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Definitely doe the 3:90
I did the 4:10 center chuck swap and wish I had taken the 3:90 instead now that I have a 235 in place of my 216...I still can't use first gear
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks guys i checked patricks already. they have nothing for the 3/4 ton and advised me to do the 4:10 swap i'll checked carters web catalog and they don't specify 1/2 or 3/4 ton. i'd bet their ring and pinions are 1/2 ton i'm sure someone on this site would have done a 3:90 swap using carter by now anyway i'll check today
thanks again
rolf
1963 c10 | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I found mine by searching junkyards online. I can't remember the name of the site but the guy was knowlegible and they inspected the center chuck before shipping.
I had the address on my old computer before is crapped out. It was something like east west auto
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I think you might also check the website of a vendor in Vancouver, WA. It is www.chevysoftheforties.com They have a big inventory and trucks is a part of what they do. Ask for Chad. He is a knowledgable person. | | |
