| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | I'm trying to get my frame stripped so I can take it in. I'm removing the front axle and springs now and am trying to pull the pitman arm. I went to napa to get a puller and all they had was one that was pretty wide. I didn't think it would fit in the indented area (not sure how else to describe it). The truck is a '53 chevy 3/4 ton. The napa part number if someone wants to look it up was Part Number: SER 2289. Do they make these in different sizes, is there a specific one I need? I tried to use my little bearing/pulley puller (its not very big) but it kept slipping off when I got quite a bit of pressure on it. Any ideas?
'53 Chevy 3604 Five Window Cab ('56 235)
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you have a tool rental place around, they'll probably have one that will work
Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I borrow the one at Autozone. It is free
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | are yours smaller than the one I listed? I'm in a rural area, the next place closer than the napa 20 minutes away is 40 minutes. I'd kind of like to know what I need before I go if I could.
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | "it kept slipping off when I got quite a bit of pressure on it. Any ideas?"
Paul, try putting a clamp across the jaws to hold them together. Then put some tension on the puller bolt and tap the bolt with a hammer. The shock will often separate the parts.
Another trick that works is to tension up the puller bolt than hold a heavy item like a sledge hammer head against one side of the pitman arm at the shaft hole and smack the opposite side with a hammer. I've removed stubborn ball joints that way.
You can do it!
Ray
| | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | that worked great! thanks a ton. I was able to get the steering column off, the front axle, and I got the springs off! I took tons of pictures of everything - of how the spacer was facing on the springs, how the shock absorber plates were on, everything. Now time to work on the rear end and remove all the little stuff like emergency brake cable, brake lines, etc... I found a shop about 60 miles away that a friend used that said they would give it a full blast (with something ceramic - they said that way it wouldn't look blasted), an acid bath and a full powder coat of black, 60% gloss. For $225, I can afford to truck it down there and back. thanks guys
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Paul, that sounds like a REAL bargain. Please keep us posted on what/how they do it and how it turns out when you get it back...maybe a pic or two if you'd be so kind.Thanks | | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | You know, I've never put a pic of any part of my truck I don't think. Because I've never actually gotten any of it done. I guess this will be a first. If this goes ok, by the end of summer I should have a rebuilt motor and a finished frame at the very least. A mechanic for the company I work for is the one who told me about this place. They produce wood stoves (or furnaces) and have the room to do this sort of thing during their slow times. I'll let you know, but I'm not sure how to post pics except to copy and paste them in the posts.
