7 members (TUTS 59, homer52, Otto Skorzeny, Youngin' Tut 59, dt235sd, 2 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
I am restoring the bed on the truck now. 63 shortbed stepside. I have replaced the back bed panel and tailgate, have all new strips and bolts, but the angel strips are a problem. Are they welded in? They are most definitely original, but not bolted to the bed side. I have new strips and ordered the ones that are punched, but there are no holes to mount to the sides. Any be great
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
The factory edge angles are welded in place, but the spot-welds can be easily drilled out, in order to remove them. Be careful not to go through both the angle strip and the bed side, since you will be putting new ones in place. When installing the new ones, I drill holes in the new strips and puddle-weld them to the bed sides. After top-dressing the puddle-welds, they look close to factory. They can also be drilled and bolted in place with carriage-head fasteners.
I can tell you that when you remove the strips from the bedsides the bed sides have a tendancie to warp. I like the idea of welding them back in but I used polishes stainless steel. You didn't say what strips you were using. good luck, we like pics too!
My 1961 Chevy Pickup Truck
In the GalleryMy Webshots Shoebox
Z
Z Offline
Jon1963,I noticed in a Jim Carter's Classic Truck magazine,you can order the angle strips,on the bedsides,that will fit over the existing strips,without any welding,or drilling. Check it out might save you time,and frustration,just a thought.Good Luck.
The cover strips have to be attached in some fashion, whether they are drilled & bolted or welded, in order to attach them over the existing edge strips. I don't recommend installing them over rusty ones, since they are rusting from the inside out and the covers will only serve as a band-aid.
I purchased polished stainless steel strips, sorry I didn't pass that on. I don't do welding myself, so I think that I'll just bolt them in w/carriage bolts. The reason I didn't go with the covers is that the angle strips on the truck are in terrible conditiona and I want to replace with new strips and hardware. Thanks for all the help.
