4 members (Hotrod Lincoln, KCMongo, Peggy M, eclector), 166 guests, and 2 robots.
Topics128,034
Posts1,055,533
Members48,425
#736635 04/06/2011 3:02 AM
I have a 230 or 250 engine from a 1965 chev full size car with a 3 speed. Engine block serial number is FO216FA next to dist. and casting number is 3877178. Is this a 230 or a 250? Thanks
Bill garvey
According the the GM Heritage site, it is a 230.
Bill Burmeister
The blocks are the same, they changed the crank to a longer stroke for the 250. If you can get a look in the spark plug hole at the piston tops, you can tell the difference. 230 will have four valve reliefs like 90% of all engines have, the 250 will have one big dish right in the center that takes up the whole piston top.
230 http://www.summitracing.com/parts/SLP-235NP30/?rtype=10
250 http://www.summitracing.com/parts/SLP-403P30/
The rest of the engine is all the same except for the camshaft spec's, the 250 has a slightly bigger cam.
http://www.hotsixes.com/index.php?option=com_content&view=article&id=2&Itemid=3
Joe
Joe H #736773 04/06/2011 4:04 PM
250 engines were not available until the 1967 model year so your 65' would not have it as an original engine.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
1966
My 66 C10 had a 250.
Oh, I don't know about cars.
Professional Novice
