3 members (TUTS 59, Jon G, Joe H),
97
Mod | | | Forums66 Topics128,026 Posts1,055,402 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Not sure if this should be here or in the electrical area, but here goes: A friend has this bus, about '68-'72, not sure, and he is trying to locate the alternating flasher unit; we think it is the motorized type, not just a regular flasher. We looked in the switch console with no luck. Does anyone know where it is located, or if it actually has a motorized flasher??? Thanks in advance.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I'm fairly sure that what your looking for would have been installed by the bus manufacturer. If you don't find the flasher start looking into the info from the bus body dealer or body builder. Google the body brand by name and see what you get. I used to work on a lot of School Bus C&C's and don't remember any of them being equipped with a special flasher unit. I'm sure they were installed by the builder. Did you check behind the panel above the windshield and the one at the drivers left elbow? | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Thanks Dave, I'll do more checking. Anybody else?????
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | motorized would be a bus only sort of thing that depends on the mfgr .... might try tracing wires from the column unit, and of course if it works at all, sound might find it
Bill | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Depending on the Manufacturer, the flashing unit should be in the side dash panel, next to the drivers seat. Would have been motorized originally, but can be converted to electronic(the way to go). I just happen to be a School Bus Mechanic by trade. 29 1/2 years experience with the N.C. Public Schools School Bus Transportation. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Thanks to everybody that responded. I'll see my friend later this week and we'll see if we can find that flasher. Stovebolt is great!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Just noticed you are in North Carolina. If that bus was run in the N.C. public School system, it's more than likely a Thomas Built, or Blue Bird body. | | |
