1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
#73686 02/22/2007 3:47 AM
Apprentice
Apprentice
I did some searching and couldn't quite find what I'm looking for so here goes. I need to replace the 235 in my 57 3200 long bed stepside and want to know what years newer than the 57 would be straight drop ins. I want to stick with the 235 and my block has a major crack at the #2 main journal and I can't use it. :confused:
#73687 02/22/2007 3:53 AM
You can use up through 62. The most you'd run into is bellhousing or front mount variances but both are easy fixes, especially with both engines out of the vehicle.
Evan
#73688 02/22/2007 3:57 AM
I see 235s on Ebay a lot. A little patience and I'll bet you can find a matching '57 block in CA. Be sure to post a parts wanted ad here and at Inliners.org. Larrowe and sons in Portland could probably help you out as well. He'll ship to you. Good luck.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#73689 02/22/2007 3:58 AM
58-62 ohwell 62 was the last year of the 235s. As long as your going to change it anyway... why not a 261? It is still a bolt in change, and will make your 57 a pleasure to drive. There are some small things you may have to do to accomplish the swap... example: the 60-62 235s used a hydralic clutch you would have to use your 57 bellhousing and clutch linkage.
#73690 02/22/2007 4:00 AM
Wow... I guess I type slower than I thought! grin
#73691 02/22/2007 4:03 AM
You know I agree with the 261 thing. No one would know but you, you can even use your 235 valve cover, intake/exhaust, ignition system, thermo housing, waterpump, aircleaner, linkage, etc...
My Webshot Photos]
#73692 02/23/2007 2:25 AM
Apprentice
Apprentice
Thanks for the info. I'll try the postings and think about the 261.
#73693 02/23/2007 3:20 AM
1959 was the last year to have a place for the front side mounts needed to mount a 235 in your truck with original mounts.
My Blog
#73694 02/25/2007 10:33 AM
Apprentice
Apprentice
Thanks for all the comments. I did a little research and I have to agree the 261 sounds like a winner. I will be posting an ad here and Inliners Org
