9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | OK guys get your measuring devices out! I have installed a Turbo 350 w/6"tailshaft onto my V8-327 and a 10 bolt Oldsmobuble rear end in my 1948 Chevy short bed Thriftmaster. From center to center of the caps on the u-joints, how long should my driveshaft be? (With the space needed to move back and forth in the tranny) Thanx for your help! Mike | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | wouldnt think they'd all be the same.....depends on wher you located your engine, tranny,rear end etc...to many variables.....dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Mike, Dennys Driveshafts tells you how to measure for the proper length,http://www.dennysdriveshaft.com/how_to_measure.html Hope this helps! Frank | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey coach-frank, I just printed his measure form and wrote down my measurements but I'm not sure howmuch play to add for the trans yoke. My measurements come out to 55 1/2" by their diagram and they say that they will subtract for the proper amount of slip travel. Thats what I dont know, before I cut and reweld my shaft.
David your wright also but I thought with these measurements some one would be able to give me a close figure.
Thanx guys! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The guy who cuts most driveshafts here in town, and has been doing it for about 40 years says my drive shaft can go in ONE inch and out TWO on "most standard" vehicles as a "general rule" Here is a copy of the sheet he gave me on how to get the measurements for him. Hope it helps someone. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/img011.jpg
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Bowtiesr4me, if you have a friend or neighbor with a lathe and welder you can modify a stock driveshaft with the correct yokes to fit your length. All that is required to shorten a driveshaft is to put it in a lathe and machine out one of the yoke welds and chop the tube to the desired length creating a square end. Then the yoke is inserted into the stub and rewelded and the job is done.
I've only done a couple of those and neither one vibrated. If it does vibrate a driveline shop can balance it. It's no more complicated than balancing a wheel. A small weight like a washer is tack welded on.
Ray
| | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Thanx yar! I have just the right man for the job.(good Retired mechinest)
Achipmunk, Thanx for the pics also, this way I know where to tell the man where to place the yoke.
HAGD! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Bowtie: yar makes this sound simple and it is IF your experienced and know what your doing. First and foremost is to be certain the yokes are in phase. If you don't understand this then take it to a driveline shop and have it done. It is nor expensive, I have years of experience building driveline for anything you can think of. probably 15-20% of our work was fixing the home-brew repairs.
Your length of 55" is the maximum for most driveshafts used with gas engines.
