4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#719150 02/08/2011 2:33 AM
The top hinge on my drivers door needs to be pushed out about on eighth of an inch. The book says to bend the hinge.
Has anyone done this?
Dennis
This is a used replacement door that I am trying to fit onto my cab. I cannot remember if the original door fit flush or not.
I have found that no two door fit alike.
Dennis
Dennis, I've heard of the procedure but haven't done it myself. Good luck.
Hi Martin. I found another hinge while cleaning my garage. I will replace this top hinge first to see if that does anything.
Thanks for the info
Dennis
I put a pry bar at the inside of the hinge and pushed the door shut. Now my door fits fine. I have always heard that the factory workers had two-by-fours and bars close by to bend the doors. It works.
Dennis
Back in the late 50s/early 60s, my dad had a used car lot and body shop. I remember as a kid seeing him or one of my uncles put a hammer handle in a door at the hinge and close the door and push hard. When the door was like they wanted it, they took out the hammer and the door fit great.
Hugh 55 trk #736542 04/05/2011 9:05 PM
knowing my luck I would put the wedge in the wrong place and make it worse.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I know what you mean. I am not sure if the door moved out or the cab moved over. LOL
Dennis
