| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | The top hinge on my drivers door needs to be pushed out about on eighth of an inch. The book says to bend the hinge.
Has anyone done this?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | This is a used replacement door that I am trying to fit onto my cab. I cannot remember if the original door fit flush or not.
I have found that no two door fit alike.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Dennis, I've heard of the procedure but haven't done it myself. Good luck.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi Martin. I found another hinge while cleaning my garage. I will replace this top hinge first to see if that does anything.
Thanks for the info
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I put a pry bar at the inside of the hinge and pushed the door shut. Now my door fits fine. I have always heard that the factory workers had two-by-fours and bars close by to bend the doors. It works.
| | | | | Joined: May 2008 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 49 | Back in the late 50s/early 60s, my dad had a used car lot and body shop. I remember as a kid seeing him or one of my uncles put a hammer handle in a door at the hinge and close the door and push hard. When the door was like they wanted it, they took out the hammer and the door fit great. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | knowing my luck I would put the wedge in the wrong place and make it worse. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I know what you mean. I am not sure if the door moved out or the cab moved over. LOL
