BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
8 members (GMCJammer51, IHPWR, DJHobbit'46Chevy, Danielbolt, Dragsix, RBs36, 2 invisible),
556
robot. | Key: Admin,
Mod | | Forums66 Topics126,780 Posts1,039,296 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Mar 2011 Posts: 11 New Guy | New Guy Joined: Mar 2011 Posts: 11 | mate i dont know about there being different sizes but i would think they would be, a 2t box would have to handle more weight than a 1/2t box. are those bolts in yours high tensile? dont look as though they are, they have a lot coarser thread than the ones on the fitted steering box. Please check this out mate | | | | Joined: Feb 2010 Posts: 20 New Guy | New Guy Joined: Feb 2010 Posts: 20 | are those bolts in yours high tensile? those bolts are for mock up | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I have a book that shows 41 to 46 steering gear with part numbers but it does not show a part that looks like yours. If I knew how I would send you a picture. Monroe McKill
Monroe McKill
| | | | Joined: Feb 2000 Posts: 4,886 'Bolter | 'Bolter Joined: Feb 2000 Posts: 4,886 | According to this, all the trucks except COE use the same box, http://chevy.oldcarmanualproject.com/1929_54chevyparts/06/393.HTMso you can rest easy there. In my parts book, Section 7.234 list mounting brackets for steering gear. 1937-1946 ALL COMM. and UTIL. (exc. COE) casting #594460, part #594460 1939-1946 COE casting #3650577 part number 3650577 Joe
| | | | Joined: Feb 2010 Posts: 20 New Guy | New Guy Joined: Feb 2010 Posts: 20 | Hey Joe & Monroe, thanks for the information.
The mounts are confirmed to be different (thanks Tim!), primarily in how the mounts place the box itself. If I was desperate I could probably mill the mount down, but I'd rather locate the proper 1/2 ton mount. Hollanders didn't list them but it did let me know I had the proper box.
Part #'s look the right except on one of the mounts which has PN# 594458. Joe - what parts book are you using? I was wondering if there was a Chevy equivalent of the Ford Green Bible.
Thanks for the replies, I appreciate the help!
| | | | Joined: Feb 2000 Posts: 4,886 'Bolter | 'Bolter Joined: Feb 2000 Posts: 4,886 | I have two books, one is a 1929-1942 parts manual, the other is a 1929-1949 manual. These are just older versions of the one I linked to ( http://chevy.oldcarmanualproject.com ). Just look for parts manuals. Joe | | | | Joined: Feb 2010 Posts: 20 New Guy | New Guy Joined: Feb 2010 Posts: 20 | Hi Joe, thanks for the information.. looking it up right now. | | |
