4 members (Shaffer's1950, Ponchogl, mick53, Hotrod Lincoln), 150 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
I am rebuilding the wheel cylinders on my'37. Is there a publication on adjusting the rear brakes or can someone help me out?
Ex Hall Monitor
Ex Hall Monitor
If it still has the huck brakes turning the ends clockwise make the brakes tighter and CCW makes them looser. Turn each CW until you feel a slight drag & back off one click. I don't know if that's "text book" but it works for me. You have to adjust each side of each cylinder individually.
Thanks, that's what i thought, I just wasn't sure.
I realize you have probably finished your adjustment already, but I just saw the post. According to the 1940 shop manual (same huck brakes,) they say tighten to slight drag then back off 4 clicks. Also, disconnect E-brake so as not to get drag if cables are out of adjustment.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
