| | | Forums66 Topics128,162 Posts1,056,917 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | I am rebuilding the wheel cylinders on my'37. Is there a publication on adjusting the rear brakes or can someone help me out? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it still has the huck brakes turning the ends clockwise make the brakes tighter and CCW makes them looser. Turn each CW until you feel a slight drag & back off one click. I don't know if that's "text book" but it works for me. You have to adjust each side of each cylinder individually.
| | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | Thanks, that's what i thought, I just wasn't sure. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I realize you have probably finished your adjustment already, but I just saw the post. According to the 1940 shop manual (same huck brakes,) they say tighten to slight drag then back off 4 clicks. Also, disconnect E-brake so as not to get drag if cables are out of adjustment.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
